Determining status of 60 engine
farmerboybill
07-15-2004 18:03:45
I'm still considering whether or not to buy that 60 and would like to know the easiest way to figure out if the engine is seized. I figured I'd pull it but I'd hafta raise the cultivators and put air in the rear tire. My second thought was to hook jumpers from my pickup's battery to the 60's battery and try to crank it. However, I'm fairly sure my truck's system is 12 volt and the tractor's is 6 volt. Is this gonna hurt it? Also, if the engine is not seized but has some other damage like a siezed valve, will I cause major damage? How would some of you determine whether or not an engine is siezed?
The guy agreed to let me buy it for labor so this might be a good deal for me depending on how much he thinks I'm worth an hour.
Thanks for advice.
Forgot to tell you
07-16-2004 03:24:35
 Re: Determining status of 60 engine in reply to farmerboybill, 07-15-2004 18:03:45
Farmer the electric system is 12 VOLT AND IS A POSITIVE GROUND ( thats the way it was in those days ) Mr. JD Clooney or John T will tell you the same thing. Hope you get it to going. North Ala.
Ron
07-15-2004 20:28:07
I think the 60 was 12 Volt anyway....
If for some reason it has a 6V battery in it, remove it, and use your jumpers connected to the positive and ground cables. That way you don't need to worry about a battery exploding... 12V won't hurt a 6V starter IF you don't hold it engaged for more than a few seconds, and don't allow it to spin up too high if it doesent engage..!! I have used 12V on my 6V starter for the last 10 years and have had NO trouble...( converted the battery and lights to 12 V )...Ballast resistor on the coil....Changed it to + Ground and use a Ford Alternator...
CLW
07-15-2004 19:35:40
Make sure the tractor is out of gear, push the clutch in and turn the belt pully by hand. Remove the plugs if it won't turn and try again.
CLW
Nor. Al
07-15-2004 18:47:41
Farm boy You can jack it up remove plugs put something like marvel mystery oil in it ,put it in 6th gear and gently rock wheels ( don't exert a lot of force if they don't turn as you can break crankshaft or burst a piston )if it won't turn put plugs back in and let oil penatrate for about a week, I think some of the guys use vinegar to break rust. I have just finished restoring a 60 that had not been run since 1988, and believe me we got some men on this forum that can guide you through about any problem you encounter. Been there & done that. Good luck
