3010 intermittent clutch problem
bider
07-15-2004 14:50:40
my 3010 clutch has been working off and on the past week. sometimes it's perfect, then it won't engage (or engages very slowly with no power) into any gear even with the pedal all the way up (it's already adjusted all the way out on the pedal). Do I need to split the tractor and redo the clutch or is there something else possibly wrong? Thanks for any thoughts.
msb
07-15-2004 20:07:04
 Re: 3010 intermittent clutch problem in reply to bider, 07-15-2004 14:50:40
2 Things: The early(maybe all 10 series,its been 40 years-expect me to remember?lol) 3010 & 4010 series round dowel pin holes in the clutch pack were held to too tight a tolerance during manufacturing.The pressure plate hung up on the dowels and causes the exact problem you describe.Pushing the pedal down took a lot of effort until they were drilled out.Sometimes the clutch would stick and not release.There was a service bulletin way way back that gave the recommended size to drill the holes out.I am thinking it was 11/16".(Should remember as many drill bits as I sharpened)Could be wrong.
Second thought is one or more of your 3 operating bolts could have gotten out of adjustment.It is even possible one of the operating bolts has broken.But they always broke when the driver headed for the gas tank.LOL.Usually the operator has no clutch at this point.Luckily ,never heard of anyone hitting the tank and getting burned up. Sure scared a bunch of farmers when it happened though.
DON
07-15-2004 15:20:38
IF THE ADJUSTMENT IS ALL THE WAY TO THE TOP , IT'S FRIED. SORRY , IT WILL NEED TO BE SPLIT. DON
