Clutch Drive Disc Removal 1946 JD Model B Help
E Ray Hardy
07-15-2004 13:37:47
I have just begun restoration on a 1946 JD B. I wanted to put new clutch discs in but now I can't get the drive disc out. I already broke a piece out of it using wrong type puller. Now I have 1/2 inch bolts in the slots and a fairly heavy puller but it just wont break loose. I have used PB Blaster---WD40---some heat with no success. Any suggestions will be appreciated.
John T
07-15-2004 13:52:20
 Re: Clutch Drive Disc Removal 1946 JD Model B He in reply to E Ray Hardy, 07-15-2004 13:37:47
Ray, when such things are that tight, I use my torch and try n heat all around n around n around the driver perimeter just near where it mates with the crank. I usually crank the puller down tight, then heat all around the perimeter, tighten the puller a bit more and maybe apply a few shocking hammer blows if necessary, then tighten the puller, apply more heat, retighten etc and HOPEFULLY she will pop loose. What do you have in the crank end threads (after you removed the big outer bolt n washer). If you can get a hex bolt or allen head in there or a spacer/bushing etc with a good dead center hole/recession for the puller, it will help.
Youre probably gonna need more heat if you havent tried that yet.
Sorry I have no other tips or ways, maybe others can offer some good tricks.
Good Luck n God Bless
John T
