160 ft/lbs enough torque for Model D head bolts ??
Michael esch
07-15-2004 13:20:14
I put the limit of my torque wrench (160 foot pounds) on the head bolts of my Model D.
It has stock fuel pistons and compression, my question is do I need more ?
Logic would dictate a 3/4 inch stud torque at a little over 200 foot pounds, is that much needed in this case ??
Thanks
Duane Larson
07-15-2004 14:56:00
 Re: 160 ft/lbs enough torque for Model D head bolt in reply to Michael esch, 07-15-2004 13:20:14
Michael,
The D head bolt torque is 208 ft-lbs. I made an extender for my torque wrench from a piece of steel. If the extra arm is equal to the length from the center of your handle to the center of the male socket on your wrench, you double the reading. So, a 100 ftlbs reading would be a torque of 200 ft-lbs. If you extension is half the length from the handle to socket, the reading is 50% more - a reading of 100 ft-lbs would correspond to a torque of 150 ft-lbs. You get the idea. I used a piece of 1 1/2"x1/4" steel and just welded the appropriate male/female socket piece on each end to adapt to the torque wrench. Be sure the extension is in a straight line with the torque wrench arm, otherwise the readings are more complicated - if the angle is 90 degrees the multiplicative factor is one.
Off to our 2-cyl club meeting - hope this helps.
G-MAN
07-15-2004 13:43:22
I would definitely torque to the recommended spec, heat the engine up good and retorque. They wouldn't specify 200+ if 160 would do it. Borrow or rent a torque wrench with sufficient capacity. The 3/4 studs on the "70" all-fuel I just put together called for around 205 lb-ft. I'm sure the "D" is probably supposed to be that much or more. Regardless of compression or intended use, the required torque is needed to get proper clamping and prevent leakage. It's not worth having to redo the head gasket for want of a torque wrench, is it?
Michael esch
07-15-2004 18:29:27
 Re: Re: 160 ft/lbs enough torque for Model D head in reply to G-MAN, 07-15-2004 13:43:22
Thanks,
I found a torque wrench for cheap at Harbor Freight tools for 67.99 it is 3/4 drive and 48 inches long with plenty of torque.
