Bullrunner, If air comes out the petcocks, I doubt they are the problem and probalby no need to remove or clean them. HOWEVER, its gas vapor NOT just air thats gotta be coming out them for her to start. How are you choking it and after a start attempt are the plugs wet or bone dry???? (If always bone dry, shes not getting enough gas) Heres a few preliminary things to look at. You gotta have spark at the plugs (you say you have that) fuel n compression to run you know. 1) Open the carb bowls lower drain cock/plug, turn the gas on, and insure a steady stream of gas rus out a minute or so approx 1/16 inch in diameter. If youre seeign air and NOT vapor out the petcocks, Im wondering if the carb and float n needle and gas supply to the carb etc are all okay. ARE ALL THE FUEL VALVES ON??? 2) If gas is good to the carb, see if the choke butterfly plate is tight on its shaft and closes n opens fully and stays where you set it?? 3) If you choke it enough and theres gas in the carbs bowl, she ought to eventaully cause some vapor out the petcocks. Thats if she has compression and the valves etc. are working. 4) Remove the air cleaners bowl n see if its full of oil and NOT water and inspect the air cleaner mesh and air pipe to the carb for restrictions. There could be plenty more reasons and BOTH cylinders should be close to each other in their compression. Check it for both and see how it looks. If low, try removign the plugs and squirt some oil in the cylinders and then see what happens. Make sure the carb is getting gas per Para. 1,,,,, ,,, then take a look at your compression and air cleaner and air inlet pipe/system,,,,, ,,,then the choke,,,,, ,adjust the carb tops needles to idle at 2 turns out and power to 1 out,,,,, see what happens. Maybe the carbs bowl isnt filling with gas or youre not really choking it enough if the plugs always show bone dry and theres air but no gas vapor out the petcocks. Also remove the fuel line to the carb as it should flow a steady stream if the gas is on. What kind of fuel valves you have??? A sediment bowl shut off?? a Brass 3 way valve??? They all gotta be open and directed to the carb ya know. Good Luck n God Bless John T
