JD 2950
pasbon
07-15-2004 05:36:57
Am looking at a 2950, is there any known problems out there that I should be aware of or to look for? I figured someone out there has run one of these and knows... Thanks for all the help from you wonderful people that are sharing your knowledge...
Don
07-16-2004 19:34:03
 Re: JD 2950 in reply to pasbon, 07-15-2004 05:36:57
We have run one for the last six years. FWD open station with high/low on the dash. It is a very nice tractor with an engine that has a great power curve. The only problem with the tractor is the price of JD parts. We lost the throw out bearing at about 5000 hrs and decided to replace the clutch since we had it split. JD replaced the disk with a larger one and it required the flywheel to be machined to accept it. $800 later, it was back running. Same job on my IH was $150. The syncro trany is great and there is a speed for everything. The hydraulics are good but complicated. Our SCVs leak pressure in neutral position and the three pt hitch falls when off so it has an internal leak. All the repairs are not that hard but require the castings beneath the seat to be pulled to replace the offending O'rings. I would say condition is the most important concideration since when everything works , it is a great tractor, but when something doesn't, you have to pull castings. You have to pull the axle to replace brake pads. Luckly, I have not had to do that yet, but it will be soon with the size trailers we pull. Hope this helps.
