GP power shaft seals
Marty Z
07-14-2004 17:17:59
I need the 2 oil seals that go on the ends of the power shaft... The book shows them to be ---- C 1416 R. Greg Stephens says he can't get them. Any one have a seal solution that fits ? Duane Larson- What did you use in your GP's. There must be an automotive seal out there that is the right size.
Thanks
Marty Z
Curtice Ohio
paul ostrander
07-18-2004 16:17:02
 Re: GP power shaft seals in reply to Marty Z, 07-14-2004 17:17:59
We have used a number of CR lip seals in place of felt washers with satisfactory results in our GP tractors. Sometimes I kept records of part numbers used. I believe the CR seal replacement for the felt washers on the power shaft is 11171. As I recall, it is used on both ends. Be advised that the biggest problem with the PTO/lift units is leaks of transmission fluid into the PTO around the shaft (with the driving gear on it) which is inside the transmission. When the PTO unit gets too full, oil will come out somewhere.
Phil Maria
07-15-2004 09:42:40
Try the C-R Seal web site, they have product information on the site that you can use to select a lip seal. I used then on my GPWT PTO shaft and they were an exact fit with no machining required.
You're in Curtice? Is that by Toledo?
Marty Z
07-15-2004 22:48:14
 Re: Re: GP power shaft seals in reply to Phil Maria, 07-15-2004 09:42:40
Thanks Phil and ET...
You got me going in the right direction
MJZ
Yes I am about 10 miles east of Toledo Ohio
Still gonna contact the ostranders to see what they do with this problem.
ET
07-15-2004 07:09:45
On my GP I ran into the same problem. I found a lip type seal that fit the shaft ok but the outside diamiter was a problem. You may need to get the bore machined to fit an availabe seal. The seal I found was a few thousanths to big on the outside diamiter. I got the seal in there but there was to much crush, it doesn't leak but if I were doing it again I would have the housing machined for a perfect fit.
Duane Larson
07-14-2004 18:41:33
Marty,
I haven't been into mine (yet) so don't have the part number. But if you take measurements of your shaft and the recess for the seal to a good bearing place they can recommend a lip seal that will fit. I assume C1416R is a cork seal?
You might also contact Cork (Corwin) Groth in Iowa next week (he is at EXPO this week) and he probably knows the seal number. Or Michael or Paul Ostrander may also know, but they are also at EXPO, I assume. Phil Maria may also know.
Sorry I am not of more help, but will be interested to find out what you learn. If you need phone numbers for these folks reply back and I'll get them to you.
Marty Z
07-14-2004 23:06:56
 Re: Re: GP power shaft seals in reply to Duane Larson, 07-14-2004 18:41:33
Thanks Duane.. I will contact the Ostranders and see what they say. I Got a bunch of help from them at the gathering. I bet they know . If I find a solution, I will post it here. I don't have a mail address for Cork Groth but I bet he would have a solution for this problem. Next week I hope to get to the local NAPA parts dealer and see if they have a contact that is local for oil seals. the ones that I took out were Felt I think, but they just crumbled. Thanks for the reply
Marty Z
Ohio
