60 Power steering return line/tube
Fred from MO
07-14-2004 17:00:04
Does anyone know if you can purchase the aluminum line with the fittings that goes from the pedistal back to the suction side of the power steering pump. I have got into my 60 and after fixing most of all the leaks on the tractor noticed that this fitting was leaking excessive. When I loosened the nut and took it off it looks as though someone had overtightened it years ago. The threads on the nut are crossed. Since I am assuming this is a return line I wonder if a guy could get the fittings and just run gas hose back with clamps if this is not availible.
Mike M
07-15-2004 04:45:08
 Re: 60 Power steering return line/tube in reply to Fred from MO, 07-14-2004 17:00:04
Check with a John Deere dealer these were available a few years back new.
F-I-T
07-15-2004 08:05:16
 Re: Re: 60 Power steering return line/tube in reply to Mike M, 07-15-2004 04:45:08
Joe:
Believe it or not, that line ( AR21028R subbed for the old AF1921R) DOES show as available from JDParts.com. It's a bit a bit pricey at $112.90, so it depends just how correct you want to be when stopping that leak.
Frank
Fred from MO
07-15-2004 20:15:50
 Re: Re: Re: 60 Power steering return line/tube in reply to F-I-T, 07-15-2004 08:05:16
Yeah I stopped by my dealer today and he checked. He quoted me a price of around 95 dollars. I found a guy here local that has a used one he will sell me for $50. I am headed there in the morning.
Ron
07-14-2004 20:03:31
I would get a used pipe from "OldJD4U", or some other place. It would be an easy piece to find and it would be original.. Yes, you could get a new fitting, and put a compression fitting in, to join the ends together..
Fred's Pix #1.......F-I-T
07-14-2004 18:24:49
third party image
Fred:
Let me post the pictures here so everyone can see your predicament. As I said in the e-mail to you, I think a hydraulic quality hose, or a copper line of sufficient size or even a new aluminum could be fabricated, but hopefully someone here will know of a better solution for you.
Frank
Fred's Pix #2.......F-I-T
07-14-2004 18:25:50
 Re: Re: 60 Power steering return line/tube in reply to Fred's Pix #1.......F-I-T, 07-14-2004 18:24:49
third party image
HTH
