JD 50 Carb. Issues
Lloyd
07-14-2004 13:44:37
Wondering if there is or should I say was a spring or something that goes inside the choke cover to attach the rod to the pin? There is a stop inside the cover but no way to attach the pin and return the choke to the neutral position. Any ideas? Thanks once again-by the way it is properly adjusted and running pretty well !!
Duane Larson
07-14-2004 15:00:59
 Re: JD 50 Carb. Issues in reply to Lloyd, 07-14-2004 13:44:37
Lloyd,
Yep, there is a spring, p/n R10099, that goes inside the cast lever. Available for $5.25 on JDPARTS or from your JD dealer. It provides the contact between the lever and the choke shaft.
