Brush Hog for a 40U
Glenn
07-14-2004 04:57:55
I am interested in purchasing a brush hog to put on my 40U. This is new to me, so what do I look for? Size? Number of blades? Extras it should have? Same with a finish mower? Thanks
mike
07-15-2004 03:38:03
 Re: Brush Hog for a 40U in reply to Glenn, 07-14-2004 04:57:55
I wouldn't recomemd useing a rotary mower on a 40. No live pto,and a weak tranny.The rotary
mower will strip tranny gears very fast if you hit a rock small stump.
Bus Driver
07-14-2004 16:51:06
I had a 40U but sold it in 1978- tractor collecting not in vogue in my area then. The 40U did not come standard with a PTO, it was an accessory. The owner's manual said that the 3-point assembly had to be removed to use the PTO. I could not find a PTO (no Internet then) and that is why I sold it. Please tell me about your PTO and 3-point hookup.
07-14-2004 19:35:29
 Re: Re: Brush Hog for a 40U in reply to Bus Driver, 07-14-2004 16:51:06
Bus Driver,
my 40U came with the 3-pt and PTO. you may have to remove parts of the 3-pt (well, really only the drawbar) to install the PTO, but they can both be on the tractor and used at the same time. i can send you pics of mine if you're interested in how it all fits together, but the 3-pt is just your basic 3-pt, and the PTO shaft sticks out farther due to the layout of the final drives on a 40U.
andy b.
SteveA
07-14-2004 11:08:58
Glenn, Usually the 40 can handle a 5 foot bush hog, but if it's really thick brush you may be better off with a 4 foot. The normal bush (or brush) hog has two swinging blades with a "stump jumper" in the center, to help in hanging on objects. I don't have experience with a finish mower but would expect a four or five foot size would work. Steve
Thane
07-15-2004 09:27:04
 Re: Re: Brush Hog for a 40U in reply to SteveA, 07-14-2004 11:08:58
I have a 40W with a 5 foot King Kutter finish mower. The mower has 3 blades. I've been cutting my yard with it for the last 10 years or so, and I have not had any trouble with it.
