64 model 3020 syncro shifters
Gary in TX
01-30-2004 17:52:50
Hey guys,
Another question on the 3020. She is haveing a little trouble with shifting sometimes and I know that the first area of blame is the syncronizers but I believe my main problem is in the shifter rods that go to the trans levers. One lever has its hole wore to an oblong shape and I replaced one shifter rod(one that goes in the spring loaded connection) and I may not have got it adjusted right. Question is, could these rods being out of adjustment like this and also the wore lever cause a symptom of gear grinding at high rpms? If I idle it down low it seems to shift much better. I am assuming that the rods being out of adjustment and wore like that could cause things not too line up like they should and cause this problem. Sorry to go through all of that in such detail but thought that it might come across as what I was tryin to say better. Thanks again for any ideas.
Gary
