420 W Draw Bar mounting?
Henry J
07-13-2004 19:18:48
I thought sure I would remember, oh yeah!
This is on a late model 58 420 W. Probably the same as the 430.
I am confused (that don't take much) about how to put the studs into the final drives for mounting the drawbar. It has been over a year.
I think the short one goes to the rear and the long one to the front. Now does the long threads go in the finals or the short threaded end?
I thought ok this is easy, I will just go to the book and it will tell me how long the studs are and etc etc. I could not find it. Maybe I need to read more?
Anyone out there know the answer and can shed some light on this dilema?
Thanx
Dave - Ia
07-14-2004 17:47:13
 Re: 420 W Draw Bar mounting? in reply to Henry J, 07-13-2004 19:18:48
Henry, The short threaded end goes into the housing. There is a difference in the threads on those studs. The end that a nut goes on easy by hand is the end that goes through the drawbar. I replaced mine this spring when I did my 430. It had bolts in the front where there is a little more clearance. If they had been in the back they would have hit the bull gear.
Henry J
07-14-2004 18:04:34
 Re: Re: 420 W Draw Bar mounting? in reply to Dave - Ia, 07-14-2004 17:47:13
Dave
Thanks for the tip. I will give them a try with a new nut.
On those front mounts, did you get the bushing that takes up all the slack in the big hole in the front mount for the draw bar? I think yours is the same as mine.
Mine were missing and as I understand, without them it leaves room for movement and leads to a disaster down the road.
Good to hear from you again.
Dave - Ia
07-14-2004 18:22:16
 Re: Re: Re: 420 W Draw Bar mounting? in reply to Henry J, 07-14-2004 18:04:34
The bushings for the front were on mine. You deffinately need something in there. You also need a heavy flat washer below the bushing to hold it in. I haven't been spending very much time on the computer lately too much going on. I did get to participate in the Great Iowa Tractor ride sponsored by WHO radio. That was a great ride with a lot of good people to share stories with.
Wayne in Tn.
07-14-2004 06:39:25
Its been a while since I had those out, so can't help much. But I do remember seeing the end of one chewed off where the bull gear had run against it. Someone must have put one in too long? Maybe thats what happened to your bull gear?
