Any 2010 mechanics out there????
Ray
07-13-2004 17:28:00
On my 1965 model 2010 gas the steering started
getting jerky and every once in a while you can hear a noise.It seems to be coming from under the
clutch platform where a lever goes into the tranny housing.It acts like a coupler that's not staying ingaged and jumping coggs.Am I headed
for a split job???
Britt
07-14-2004 08:49:27
 Re: Any 2010 mechanics out there???? in reply to Ray, 07-13-2004 17:28:00
The 2010 has a splined hub on the pressure plate that mates with a shaft that drives the PTO and the hydraulic pump. These splines can wear out. If it is worn to the point that it is slipping, your are in for a "splitting headache" (sorry for the pun). If you are unlucky enough to have the 11" clutch, the JD price on the pressure plate is over $400.00. If the shaft needs replacement, they don't even support that anymore. You will have to get one from a salvage yard. You may be able to take the inspection plates off and use a mirror to get a look at the splines. If you see a lot of fresh metal shavings, I would not operate the tractor until it is repaired.
Good Luck,
Britt
Bryan
07-14-2004 08:21:32
There should be a spring on that lever that you refer to, It may be broke or gone.
RAY H
07-13-2004 20:40:00
THERE IS A PLATE ON THE UNDERSIDE OF YOUR TRACTOR THAT WILL LET YOU ACCESS THE PUMP. THE 2010's DID NOT HAVE THE BEST HYDRAULICS AND THAT PUMP IS A VERY EXPENSIVE UNIT. YOU ALSO WILL NEED TO CHECK YOUR HYDRAULIC FILTER. THERE IS A LEVER ON THE ROW CROPS TO DISINGAGE THE PUMP, SO YOU BETTER LOOK AT THAT, SINCE I HAVEN'T OWNED A 2010 IN ABOUT 20 YRARS I HAVE FORGOTTEN A LOT ABOUT THOSE TRACTORS. BUY A SHOP MANUAL OR GO TO YOUR DEALER AND SEE IF THEY CAN GIVE YOU SOME INFO. LOTS OF LUCK!
msb
07-13-2004 20:52:43
 Re: Re: Any 2010 mechanics out there???? in reply to RAY H, 07-13-2004 20:40:00
Ray gives good advice.Get the book first.There is a hydraulic line that is a bear to get to and you won't even know where it is without the book. I think it takes a short 11/16" open end wrench for the fitting.The line goes up through the bell housing if I am remembering correctly.Some were converted to hoses.Its been about 30 yeras but I also think there is a round access plate on the right side of the tractor that you just can get your hand through.
