Another parts pricing complaint.
Loren NC
07-13-2004 17:18:28
I needed a PTO seal for my 1010. Went to the dealer. He said he didn't have it in stock but could get it in a couple of days from Atlanta. I didn't ask the price because I had to have it. In fact, I told him to go ahead and order two so I could fix both shafts at the same time if they were both leaking. Went back to pick up the new seals and he said, "That will be $42." I nearly had a heart attack, but was between a rock and a hard spot so paid and left with the two seals. Cleaned up the PTO area and found only one was leaking. It was easy to get out and easy to replace. Before putting in the new one, I checked the number on it and found it was a generic National seal. Put one in, returned the other one to the J-D dealer for a refund, called a local bearing supply store and found I can get the comparable seal from them for $5.69. Oh the joys of brand name pricing! Oh well, it only cost me two trips to the J-D dealer and a bit over $15.
Rick
07-14-2004 19:20:36
 Re: Another parts pricing complaint. in reply to Loren NC, 07-13-2004 17:18:28
Do not complain about price unless you know the 2 seals are made from the same material usually you get what you pay for! I found generic JD parts a little cheaper than JD, but I will never use them again, I will always pay more for JD genuine. I found that if I can cross a bearing or seal to a John Deere part number from a non-JD machine that John Deere is usually cheaper than the local bearing supply. Your dealer maybe charges more for a special order? I recently twisted the pto shaft on my 955 discbine, this shaft is over 20ft long, my dealer did not have it in stock, I called him at 4 o'clock in the afternoon and by 10 the next morning it was at the dealership, and no extra charges for shipping. Just try that at New Holland, my neighbor had his NH discbine laid up for a month and he cut less than 10 acres with it on a new machine.
JC
07-14-2004 18:22:09
As a first-time JD customer {restoring a "D"}, I am very impressed with the parts availability. There were some NLA {no longer available} parts but I got about 90% of a lot of items. Things like governor springs that would be hard to source elsewhere - to get the correct tension, etc. Gaskets that would take a lot of time to make. I tried the generic route for common parts and found Deere to be surprisingly reasonable in some cases. I bought the Timken bearings and seals from a bearing house but Deere served me well on the rest. In some industries, about 25% of all service parts are eventually scrapped because they never get sold. That has to be added into the cost. By contrast, I have a "Universal Super Four" marine engine sitting in the garage. I may restore it, but I can't get any parts for it! You price up custom-made rod bearings, head gaskets, etc and you will appreciate the Deere parts inventory!
Regards,
JC
mike
07-14-2004 08:40:37
While, I sympathize with the problem, I lost a gear from my JD model L manure spreader, which is approximately 50 years old. The JD dealer had the new gear to me in a few days, and provided a parts book for the spreader for $6.00. Impressive, particularly when, as previously noted, one compares to other brands.
Britt
07-14-2004 08:36:48
The moral of this story is to do some checking before committing to buying parts. I'll bet that Loren will ask before he has anything special ordered in the future. The JD dealer should be commended for taking a special order back.
If you think some of John Deere's parts are overpriced, try buying aircraft parts sometime. I have had to tell a customer that the replacement bail that holds the fuel sediment bowl on the gascolator is right at $100.00. It looks similar to the one on a John Deere 2010. The problem is, that I cannot legally put anything other than an approved (by the FAA) part on a certificated airplane. (#1 it is dangerous to use unapproved parts on an aircraft and #2 the fine could be $20,000.00+ with jail time added depending on the outcome.) If you look at the part, it is a bent wire with a 10-32 stud shot welded to it with a pressed steel cup & nut to tighten against the fuel bowl. A fair price for that part would be $5.00 or less. The aircraft owner thinks that I am ripping him off. When he really gets upset, I invite him to get an approved part cheaper. I have yet to have someone succeed at that. I always try to give the owner the best deal that I can. But I have to make a profit on anything that I sell also. I usually don't charge the suggested list price, but New Piper Aircraft has net pricing on some parts that are 95% of list. That makes it hard for anyone to get rich selling OEM parts.
These old tractors are a great hobby to enjoy. And if properly cared for they can still pull their own in the field if need be. I use my 620LP to keep the road to my house dressed and to move logs around the property. I grew up on a 720 gas rowcrop with a wide front. It was our "BIG" tractor. I really miss those days.
Britt
Rodney A Johnson
07-14-2004 07:50:53
A few years ago I bought a JD 336. Many of the teeth in the pickup needed replacing. Because the baler was old and I didn't want to pay "brand name" prices, I bought a number of teeth from Mills Fleet Farm.
As it turns out, I was still short some teeth. I happened to be in the JD dealer for some other parts, so I cautiously bought two more teeth.
I got home and compared prices and found out I payed almost double for the ones from the generic fleet store vs. the ones from JD. Plus when I installed the teeth, the ones from JD fit better, had better spring to them, and were uniform. The no name ones did not fit as well were at all odd angles and had much less spring to them.
Thus, not everything is more expensive at JD...those no name places sock it to ya too (plus they can be worse quality).
G-MAN
07-14-2004 07:43:19
That's called paying your dues, and you'll know better next time that items like seals and bearings are nearly ALWAYS available cheaper through other sources than from dealers. A bearing house gets the parts in bulk from the manufacturer in the manufacturer's packaging. Deere also gets them in bulk from the manufacturer, but has the added overhead of packaging them in their boxes, storing them in a warehouse til they're needed, paying people at the warehouse to pull the parts and package them for shipping and so forth. Of course, I also wouldn't blame the dealer if the next time you want something special-ordered they tell you to go jump in the lake. Like was said, you could have done your homework first and saved EVERYONE time and money. And don't always think that bearing houses are going to be cheapest. I suggest you go price Timken bearing cups for the rear axles on a '48 John Deere "G". $280 per cup last time I priced them because "there are only 12 left in the Timken system". I put a wanted ad on here and had four brand new ones for what one would have cost - and they came in Case-IH boxes.
Denny
07-13-2004 20:38:35
I think you should be glad that the company (John Deere) is still suppling parts. Try to get something for a IH, Case,MM, Oliver, Ford, or AC. I don't want to sound like a jerk, but be glad we have parts.
RickB
07-13-2004 18:15:06
So instead of tearing down the seal, getting the number from it and checking the bearing house, you opted to take the easy way out and order the OEM seal from your Deere dealer. The dealer didn't "cost" you two trips, you wasted one trip by assuming he had a seal for a 40+ year old machine on the shelf waiting for you. The second trip was necessary because you didn't even check to see how many seals you needed before ordering. Since you are not complaining about a re-stocking charge, it seems the dealer is eating your mistake. His cost on the unsold seal is more than his gross profit on the one you "overpaid" for. IF he can return the unsold seal to mother Deere, he will surely not recover all of his cost in ordering it in for you. Offering this level of service, you expect a rock bottom price. Sorry to rant, I just have no sympathy for you.
Jim
07-13-2004 19:04:41
 Re: Re: Another parts pricing complaint. in reply to RickB, 07-13-2004 18:15:06
well RickB, next time you go to the Deere parts counter, just bend over it, spread your legs and lets them shove it up as far as it will go and I hope your still smiling!!!
Scott44B
07-13-2004 20:21:57
 Re: Re: Re: Another parts pricing complaint. in reply to Jim, 07-13-2004 19:04:41
I'm with Rick on this one. Lack of planning on one's part does not make it the dealers fault if one thinks he paid too much. Didn't price it and then ordered two without even checking what you needed, I wouldn't even want anyone to know I'd done something so silly. I've run a JD parts department & it is no easy thing to turn a net profit at the end of the year, even if you think you're being bent over the counter. There are a lot of things that go on behind the scenes that need to be done to provide good parts service for a range of equipment 50+ years old to the most modern tractors that drive themselves. All this technology comes at a price and some of the old equipment has to help support it.
