1937 john deere B
fred
07-13-2004 14:27:31
Looking at my first John deere.
All I intend to do is show the tractor.What do you have to do to start one of these old girls?And shut it off.It has a wico C mag.Don`t know if this is good or bad.
Any help appreciated,Fred.
John T
07-13-2004 15:07:17
 Re: 1937 john deere B in reply to fred, 07-13-2004 14:27:31
Fred, thats a pretty wide open question, if you have fresh clean gas, a good properly adjusted carb, and a good engine with a good hot mag and good plugs etc:
Put the tranny in neutral,,,,, ,(I prefer clutch engaged then),,,,, set the brakes,,,,, ,,,turn the gas on,,,,, open the throttle some,,,,, ,,give her full choke,,,,, ,grab hold the flywheel and turn her over CCW maybe a couple times on compression for each cylinder,,,,, ,,,open the choke somewhere between 7/8 and 1/2 (you have to experiment with the amount of choke and for where for how many turns etc etc and temp sure makes a difference in startign procedures),,,,, ,,,turn the flywheel again and if youre lucky and the tractors ALLLLL LL in good shape, she may start, then open the choke.
To shut her off, I recommend you idle her down and shut the gas off at the sediment bowl or other shut off location (like an added inline valve or a brass 3 way valve etc) and let her run out of gas and die.
Sounds easy BUTTTTT T shes all gotta be in good shape to work that easy. I like to use Sta Bil in my gas year round and use a small can of low ash 2 cycle oil in the gas each fill up.
Good Luck n God Bless
John T [email protected]
Fred
07-13-2004 20:03:35
 Re: Re: 1937 john deere B in reply to John T, 07-13-2004 15:07:17
Thank`s A lot John T.I know A lot more than I knew before.Like I said before,this is my first experience with A john deere,Fred.
