Where to buy Batteries?
Randy
01-30-2004 17:02:08
Would you buy JD batteries ? Or are NAPA batteries just as good? Thanks, Randy
mike
01-31-2004 13:46:04
 Re: Where to buy Batteries? in reply to Randy, 01-30-2004 17:02:08
I get mine at wal mart, they are priced right, open 24 hours and are all over the place. They even give you a place on the battery for your sales slip, and another one if it gets lost.
RZ(Wa)
01-31-2004 09:59:10
Since the tractors sit for longer periods of time, the exchange warranty is what I look at after the CCA and price. A 100% replacement is always much better than a pro-rate. Thus far I've been able to straight-across exchange 4 batteries over the past 6 years without any question or hassle at the local Co-op.
RAY
01-31-2004 09:32:22
I prefer Auto Zones Gold Battery, IT cost about $75.00 for the 1000 cold cranking amps, but my major like about the battery is the warranty. All other brands that I am aware of pro rate the replacement, if the battery fails ,Auto Zone does not ,100% replacement at no charge, some of my tractors and farm trucks set a lot and this give me unlimited service from 1 purchase, But I dont use a full line of auto zone products ,some of their parts are ok some are not, I just like their batterys,mainly warranty
Jake
01-31-2004 06:59:42
I've been going with batteries made by East Penn / Deka. They last a very long time and stay clean and dry. They are sold under various names. Here in Minnesota they are sold with the CARQUEST name and also sold by Mills Fleet Farm with their label on them. Some of the batteries are quite a bit cheaper to buy at Mills Fleet Farm than Carquest and East Penn/Deka tells me they are the same battery except they just put a different label on them.
I avoid NAPA batteries at all cost. They always bubble and weep acid out the vents and corrode your battery connections and battery box. The East Penn/Deka batteries do not do that, they stay clean and dry for years.
RayP(MI)
01-30-2004 17:58:36
There are only about four major battery manufacturers - your chances of getting a good one are probably the same with most major brands.
MIKE HANLEY
01-30-2004 17:55:25
Yes I know I had one blow up,,,,BUT THAT WAS MY FAULT!!!! I didn't have it in a battery clamp and it slid ovet and the pos (NEV ground set up) gmounded on the side of the battery box and blew up. NOT THE FAULT OF THE BATTERY. Anyway I have used INTERSTATE BATTRIES for about 20 years. Just looked up the reciept of the battery I replaced the one that blew up in the 630 and all it says is "31-5 36 month warranty". PRICE $72.95 Can't recall the cold starting amps and it's too cold to go out and look, but it is just a hair more then two John Deere 6 Volts batteries hooked to 12 volt. And it just about takes up the whole battery box. Also have the same battery in the 430 crawler (Convereted to 12 NEV grund). We have two of these batteries hooked together so it's still 12V in each of the 730 diesels. (The 730D's have been converted to 12V NEV ground). These two batteries will just fit side by side in the 730's battery box. I'm thinking those batteries in the 730D WF are close to 3 years old. Last week it poped right off in 14 degrees weather sitting outside without being pluged in. I hadn't started that tractor in several days. At that temp we usually plug them in the night before we are going to use then, but old age set in and I forgot.
