3020 con rod
dwag
07-13-2004 07:40:42
3020 Diesel spun #3 rod brg. Can rod be removed from bottom after removing crankshaft?... THANKS.
Don
07-13-2004 07:54:11
 Re: 3020 con rod in reply to dwag, 07-13-2004 07:40:42
IT WILL COME OUT THE BOTTOM IF YOU REMOVE THE CRANK. i AM ASSUMING THAT YOU ARE GOING TO HAVE MACHINE WORK DONE TO THE CRANKSHAFT ANYWAYS. FRONT AND REAR OF EINGINE HAVE TO BE DISSASSEMBLED TO REMOVE CRANK. GOOD LUCK
msb
07-13-2004 20:44:41
 Re: Re: 3020 con rod in reply to Don, 07-13-2004 07:54:11
Tractor will also have to be split so I would pull the head off of it too and have valves touched up while you are at it.And remove the engine.It is a LOT easier to remove the crank if the engine is put in an engine stand so it can be rotated.There is also a balancer block that has to be removed too.Its a whole lot easier to reinstall with the engine inverted.Harbor Freight has a 1200# cap. engine stand for around $89 I think and it is big enough for a 3020.Borderline for a 4430 butI did it.Look the mains over real closely too.There is a good chance they will need replaced as well.
dwag
07-21-2004 18:23:06
 Re: Re: Re: 3020 con rod in reply to msb, 07-13-2004 20:44:41
CON ROD CANNOT BE REMOVED FROM BOTTOM!!! PISTON WILL NOT SLIDE DOWN ENOUGH TO REMOVE WRIST PIN!!! IF YOU DON'T KNOW WHAT YOUR TALKING ABOUT, KEEP STILL!!! dewag
