Henry J ( Touch-o-matic on 40T)
Gene
07-13-2004 06:34:37
Henry J, On my "TOM" leak, it is just a small crack. You mentioned the crack being in the tank. You're right, it is right where the high pressure (supply) line connects. Pressure from tightening the fitting opens it up. With the engine running it will drip one drop of fluid about every minute. I have operated the lift with no load and the leak is no worse. It appears to be just a hairline crack all the way through. No geyser, just wet. So the pressure should be only from the pump. Wouldn't that only be minimal, like water from a hose ? Thanks for the help.
Gene
Henry J
07-13-2004 12:34:51
 Re: Henry J ( Touch-o-matic on 40T) in reply to Gene, 07-13-2004 06:34:37
Gene
My thoughts are the bottom line is you can try the JB and see what happens.
As far as pressure goes, here is my theory developed at the school of hard knocks. When you activate the lift, the pressure that will build will be enough to do the task, ie raise the lift arms. To load the system you will have to have some weight for it to pick up. As you load the system the pressure will build until the relief valves in the tom will let the oil bypass, I forget but that will be around 800 to 1000 psi.
You just may (I don't know how or why) not have cracked into the pressure galley.
Let us know how it goes and good luck
Mike M
07-13-2004 06:51:43
In that case you may try that JB weld nothing to loose. Pull it back apart clean it good smear some in and on the threads reassemble and let set up overnight then retry it.
