JD '69 1020 rockshaft slow, brake problem.
Scott Taylor
07-13-2004 05:34:28
Hope someone can help. My JD 1020 was inherited from my grandfather who(I don't think) ever did much maintenance other than changing filters. When I got the tractor, I changed the hydraulic oil and filter to which was a milky color. I changed the rubber boots on the gear shifters to stop the water. I've made adjustments per the I&T manual JD-37 but the 3 pt hitch still raises very very slowly with anything attached. If nothing is attached, it raises and lowers fine. Could this be a control valve problem, using generic hydraulic oil, or the screen behind the main filter. These were my next checks but wanted to get some professional advice. Also, by brakes work great for about 2 sec. When I press on the pedal, the brakes work but then the pedal just keeps traveling to the bottom resulting in no brakes. If I keep pumping them with short burst, they will work. Any suggestions would be so greatly apprieciated on either matter!!!!
Scott Taylor
08-10-2004 09:49:00
 Re: JD '69 1020 rockshaft slow, brake problem. in reply to Scott Taylor, 07-13-2004 05:34:28
UPDATE!!! Cleaned screen, found brake problem, changed to JD hydraulic oil, checked control valve in pump - - result - rockshaft is still raising slow when something is hooked to it.
HELP!!!!! !!!!! !!
Paul Gekas
05-21-2005 23:42:02
 Re: JD '69 1020, brake problem. in reply to Scott Taylor, 08-10-2004 09:49:00
Scott what was brake problem - seems a few 1020 have had the same - I have same - would appreciate solution.
