axle modification
ags
07-13-2004 05:31:20
I'm going to take a torch to the axels on my 1020. I don't need 8" of axle hanging out in the way. Anyone else tried it?
G-MAN
07-13-2004 11:09:31
 Re: axle modification in reply to ags, 07-13-2004 05:31:20
We've cut off axles before, but we block up a cutoff saw at axle level and chop them that way. Does a much cleaner job and puts a lot less heat stress on the axle. You should be able to cut off your little 1020 axles in one chop, but on big ones, we have someone slowly turn the wheel while cutting.
ags
07-14-2004 12:47:25
 Re: Re: axle modification in reply to G-MAN, 07-13-2004 11:09:31
G-MAN, what kind of cuttoff saw are you using? Would a reciprocating saw do it?
