60 Power steering Flush and Fill
Fred From MO
07-12-2004 21:35:55
This may be a stupid question, but I cannot seam to locate where the power steering is added for the 60. The manual I have shows the front hood is supposed to have a button to knock out where you can read a cap with a dipstick that goes into the power steering reservoir. My steering is not like that. There is a tube that runs from the power trowel pump, just over the start switch, down the middle of the tractor to the power sterring pump. Then 2 hoses go to the front pedistal. I see where it drins at the bottom of the pedistal, but where is this filled at. My manual does not help me here. Anyone have any advice. I believe this is a factory PS set up from JD? Thanks Also what PS fluid can you put in this?
Mike M
07-13-2004 05:53:33
 Re: 60 Power steering Flush and Fill in reply to Fred From MO, 07-12-2004 21:35:55
I am unclear as to what you discribed,but on a JD 60 with factory power steering the power steering pump is ran from the fanshaft and is located just behind the fan blades and bolts to the front fan support and has a hose out the top and a metal tube out the top that run over the top of the radiator to the front pedestel where the power steering valve and cylinder is located.
Someone could have added a factory unit and not put the hole in the top of the grille for filling and checking or even changed the grille and put one on from an older tractor.Or if an aftermarket powersteering these usually have the steering shaft cut and are mounted between the dash and the steering wheel.On a factory unit John Deere sells a special fluid made for these.In a pinch hydraulic oil should work and be better than running dry.
Fred from MO
07-13-2004 20:02:41
 Re: Re: 60 Power steering Flush and Fill in reply to Mike M, 07-13-2004 05:53:33
Yeah I understand what you are saying. Where is the main resevoir on your unit and how do you fill it. Is it part of the pedistal?
Mike M
07-13-2004 20:14:04
 Re: Re: Re: 60 Power steering Flush and Fill in reply to Fred from MO, 07-13-2004 20:02:41
The factory units have the reservoir in the pedestal with a fill plug at top on top that has a large screwdriver slot 1 1/2 inches across, Guessing. It also has a dipstick attached you check it with the threads resting on top not screwed in.
