4430 no power steering
mike
07-12-2004 20:32:37
The 4430 blew a hose and pumped out all the hydraulic oil before anyone noticed.We replaced the hose and refilled it with oil but now the steering is tight.It takes quite a bit of effort to turn the wheel.Im wondering if the pump is cooked from running with no oil.Any ideas?Does the power steering have its own pump or scavange off the main pump? Thanks for any help, Mike
JDGnut
07-12-2004 21:26:38
 Re: 4430 no power steering in reply to mike , 07-12-2004 20:32:37
Mike.. check to see that the other hydraulics are working... You may just have a stuck stroke control valve in the main pump... JDGnut
JJ
07-12-2004 21:11:45
The actual power assist comes from the main Hydralic system. then there is a "pump-motor" under the dash at the end of the steering collum. when theres hydralic pressure the pump-motor facilitates power steering. if there is no hyd. pressure it acts like a pump and as you turn the wheel you move oil to the steering cylinder to turn left or right. if you can steer the tractor there is some oil in the system at least past the steering valve but there might be air in the lines before the valve or some where. try just steering back and forth go from lock to lock with the engine running maybe drive it around to make it easier to steer. see if it gets better
