Measure the voltage across BOTH batteries with the engine revved up to 3/4 throttle, or so. If the generator is charging, you will see over 28 volts. If it is not, you will see 25 volts, or less. Then measure the voltage across each battery, which should be very close to the same, and 1/2 of the total voltage across the two. You can also check for charging voltage at the generator, across the A1 and A2 terminals. If it turns out to be the regulator, surprisingly they are only about $50.00 from Deere! Are both batteries identical, similar in age, and in good shape? That is the other possiblity that one battery is bad. It's costly to replace them n pairs, but it's worth it in trouble saved. If the batteries are good, and the gerator is working, and has been checked out, and it is a matter of ONE battery going dead overnight, there may moisture, crud, and brush dust in the starter. The solenoid on these only disconnects ONE side of the starter from the 24 Volt system, and the discahrge of one battery through the starter overnight is very possible, even if the starter seems to work well. Moisture, dirt , and crud in the key switch will also kill a battery overnight. Another thing to try is to swap the batteries side to side, and see if the problem moves with the battery. I also have some reservations about how you have the fuel gauge and generator light hooked up, since there have been problems there, and the generator indicator light still does not seem to be working properly.
