Clutch Drive Disk '49 A
Nick
07-12-2004 14:56:14
The splines on mine are wore pretty good. The drive disk will tighten up when slid as far as it will go, but it seems too far up on the crank. How far should it be? Does the disk slide on the crank when installed correctly and the tractor is running, or is it tight? Thanks, Nick
Jack
07-13-2004 14:44:15
 Re: Clutch Drive Disk '49 A in reply to Nick, 07-12-2004 14:56:14
If your drive disc is on too far it will try to pull the tractor using the inner clutch disc and will smoke it while running with the pulley wheel stopped.I welded up the splines on a G and with a file I took my time and got her right with using the old driver.When I got my splines close I put on some Sonic Weld and pushed her up to where it needed to be and let it set for a couple of days.Four years later and she is still going to my knowlege.
Mike M
07-12-2004 18:25:20
That clutch driver is to be TIGHT on those tapered crank splines. The crankshaft should be below the surface where the large washer contacts to hold the driver on. A good one may be 3/16 to 1/4 inch from being flush. If yours gets tight but is flush it may bind up the back faceing by being on too far.You may need to try a new driver available aftermarket. Dengler's sells a more expensive -undersized ? one ,But I'm not so sure they have an undersized one because when I ordered one it was the same size as a cheaper regular one.Just beware.
