720 DES missing fuel system parts?
pa_popper
07-12-2004 10:57:23
I have a 720 Diesel electric start that seems to be missing some parts. It is serial number 7227445 and was verified by the two-cylinder club that it came as a factory electric start. The parts book shows a pipe (AR20696R, injection pump bracket vent) that connects from the fuel tank adaptor (AR20817R) down to the cylinder cover (R20591R). I don�t have this pipe.
I saw a different 720 DES this weekend that had a hole with an adaptor on the left hand side of the cylinder cover that accepted the pipe from the fuel tank adaptor. I don�t have that hole or pipe, but I do have the opening in the fuel tank adaptor. The tractor seems to run fine with out it. Am I missing any pieces that are going to cause any problems? Was this pipe for some type of venting?
Thanks.
720Deere
07-13-2004 18:54:09
 Re: 720 DES missing fuel system parts? in reply to pa_popper, 07-12-2004 10:57:23
I was hoping that Clooney or somebody else would jump in on this, but I'll give it my best.
That fuel return line was only on the late model or black dash diesels. My understanding is that the primary fuel pump on the late models produces more pressure and the return and check valve were utilized to handle the excess fuel flow when there was no demand for it. I have an early 720 that was not equipped with this. It would seem to me that if the line is plugged at the rack, that it would not be detrimental to not have the return in place. It just is not correct for that serial number tractor.
Nobody would answer you, but I guarantee you if I am wrong you will get several answers.
pa_popper
07-14-2004 11:21:28
 Re: Re: 720 DES missing fuel system parts? in reply to 720Deere, 07-13-2004 18:54:09
Thank you very much for replying! I am going to leave it alone since it seems to run fine the way it is.
