40T transmission
Steve
07-12-2004 10:56:58
I am rebuilding the transmission on a 40T. When it was torn down the cluster gear on the power shaft shows a lot of wear and corrison on some of the teath (4-6). Is it possible to weld the gear to repair the teeth and have it hold? (Deere wants a FORTUNE for a replacement...
Steve
07-12-2004 14:11:17
 Re: 40T transmission in reply to Steve, 07-12-2004 10:56:58
thanks,
I have a call into Dave Cook as well. THe cluster gear does slide off the shaft, it is AT16550T 19, 26 and 43 teeth gear. Oh, well I guess I get to wait a while longer...
Henry J
07-12-2004 19:13:53
 Re: Re: 40T transmission in reply to Steve, 07-12-2004 14:11:17
Yep I am sure John and Dave are probably doing the same circuit.
I have seen them in the same booth/vending space before.
Henry J
07-12-2004 13:39:56
Steve
I have found used transmission gears affordable as long as the gear is not part of the shaft. I don't know about your trans but the cluster gear on the power shaft of my 420 slides off the shaft.
I got my tranny gears from John Shepard 715-265-4988. He is gone basically for the rest of this month as I am waiting parts.
However I would not think that gear be that rare.
good luck
