MDM, in order for the mag to governor gasket to make a difference in hand starting, it would have to be the case where the mags coupler fits too tight into the governor that the wind n trip sprign assembly is bound up and not operating properly. In that case, a loosening of the mag or the addition of an additional gasket may allow the mag to wind n trip n fire properly. Remove your plugs to ease cranking and see if the mag makes a loud distinct SNAP and NOT a faint dull clunk or no sound at all every 180 of flywheel rotation????? ? (assuming its a non reduction drive mag like a Wico C or XH) Then have the plug wires attached and their sides against the block or frame ground and see if when the mag snaps one or the other produxes a good visible blue and NOT a faint thin wimpy yellow spark. One will spark then the other. If you dont have a good loud snap and/or a good visible blue spark, post back for ignition troubleshootign tips and let me know what mag you have. Have you tried a fresh set of plugs, maybe an Autolite 3077, the hotter side wire electrode type??? Are the points gapped properly and NOT burned or pitted or carboned up or heavy gray oxide coated?? If so, replace them. Are you usign wire core and NOT carbon core suppressor type plug wires??? If it pull starts easy and runs well but has a weak start spark and is hard to hand start, the spring could be weak or bad. Is the compression good and near equal on BOTH cylinders??? Try squirtign a lil oil into the cylinders at the plug holes and see if she starts better then ??? If so, the rings may be worn and you have low compression. SUMMARY: try fresh plugs,,,,, ,,inspect and gap the points,,,,, ,insure a good loud sharp SNAP of the mag,,,,, have fresh clean water free gas,,,,, ,,,insure the choke butterfly plate is well attached to the shaft and closes n opens fully,,,,, ,,try full choke no more than each piston pull over then set it at 3/4 to 7/8 choke and see if she starts?? try differnt needle n choke settings but if the plugs are very wet after she fails to start, you may have gas flooded it. If the plugs are bone dry, you may have a carb or choke problem and shes not gettign enough gas to start. Post back your findings and mag type and your spark quality etc and we will go from there. Good Luck n God Bless ya John T Nordhoff [email protected]
