4640 3 point and wheel weights
Stan
07-12-2004 10:00:41
I am looking at buying a 4640. Is it category 2 and 3 or just category 3? Also how much wheel weight do you recommend? This tractor has 500LBS. on each wheel. But I have seen others with as much as 1500lbs. per wheel. Tell me what you guys think.
Stan
Don
07-14-2004 06:11:57
 Re: 4640 3 point and wheel weights in reply to Stan, 07-12-2004 10:00:41
Weight depends on what you are going to do. I would leave on the 500 lbs and add duals. should pull abt anything for you. No use pulling around more weight than you need .
david val
07-13-2004 03:20:30
as far as i remember 4640's were cat 3 and 3 narrow.
david
Oppy
07-12-2004 13:20:16
The 4640 has sway blocks which will enable you to go between catagory 2 or catagory 3. If it's equipped with a quick hitch, you should be able to switch the arms on each side to accompany the catagory 2 or 3.
