Cracked
Gene
07-12-2004 07:29:31
Am I the only one to ever do this? I am working on a 40T with dual cylinder Touch-O-Matic. I was changing some old (leaky) hydraulic lines and when installing the supply line to the TOM I heard a small pop. It sounded like a thread breaking. After putting fluid in and cranking the tractor I found a small crack starting at the fitting and going about a half inch around the front. I am a small guy and was not leaning on the wrench when this happened. I want to repair it, but I am unsure what kind of pressure is at that point.
Would cold weld like JB Weld be O.K. or I am I up the creek without a paddle ?
Thanks for any help and/or opinions
Gene
1953 40T
henry J
07-12-2004 13:50:27
 Re: Cracked in reply to Gene, 07-12-2004 07:29:31
Gene
I was rethinking your post. As described it sounds like you may have cracked into the high pressure galley on the tom.
If you hadn't tried it I would crank the starter and see if oil shoots out the crack. If no squirt, I would then put a rag over it and start the motor and observe. However you don't get a back up of pressure in the system until you activate the lift lever, since before then the oil is flowing through bypass valves in the tom. So if you are adventuresome try to lift something.
If you never get a guyser, I would think you are just cracked into the tank and JB might work.
Good luck
Henry J
07-12-2004 09:25:02
Gene
I am guessing in the dark here. If you want to try a low buck fix - consider taking the tractor to the local "know what they are doing" welding shop , drain the tom, take the vent cap off and have the shop either weld or braise the crack depending on what the man recommends.
Of course this will create some ash, slag, whatever on the inside of the tom.
The other way would be to disassemble the unit and just take the busted part in.
good luck
Gene
07-12-2004 08:09:05
Thanks, but it is the TOM housing that is cracked. I don't want to have to buy a new unit.
Gene
Mike M
07-12-2004 07:59:50
This stuff is old it could be metal fatigue.
40T's should be plentiful in the junk yards I'd call around find another line.
