2nd try 146 loader question
Jay
07-12-2004 06:20:27
I'm still trying to find out if my 146 loader will fit on my 4020? If so which mounting frames do I need? The set I have now are for a 2640 and I don't think that they'll fit the 4020.
Jay
Paul
07-12-2004 19:01:21
 Re: 2nd try 146 loader question in reply to Jay, 07-12-2004 06:20:27
A very nice gentleman recently helped me with a similiar question, now it's my turn to try and help. I have a 2520 on which I recently installed a 145 loader. This loader is the same as the 146 loader only the front arms are tucked at a steeper angle to set the bucket closer to the front axle. Both are great loaders.
The loader did bolt up but it interfered with the rear side panels and the torque tube was only an inch from the eyebrow of the hood. If you look at the side rail of your 4020 there is a series of holes spaced at 3", 6", and 4" intervals. At least my 2520 was this way and I assume your 4020 is similiar only longer. I moved the loader mounting brackets forward 4" by re-drilling 3 holes in the mounting bracket, there originally were 6 holes. I was able to use the two end holes and redrill three center holes. Now my side panels fit again and there is about 5 inches clearance between the torque tube and the eyebrow of the hood.
These mounting brackets did not have rails to the rear axle or any cross member under the belly of the tractor. Reading on this forum I learned this would be a good idea since readers had experienced loose and broken bolts holding the engine side rails to the engine block etc. I built my own and did it ever make a difference. You could tell the large round bales I had been lifting were now getting the counter rotational force from the rear axle rather than putting all that rotation force on the engine side rails. Every thing was much much stiffer. All attachements to the 145 mounting brackets are bolted so as to not put any welds on the orignal loader brackets.
Since you already own the loader and tractor I suggest fitting it. Let me know if you need more details, I could do pictures. I owe my friend who helped me pictures yet.
