14t Baler questions...
Tim
07-11-2004 20:18:27
I just purchased a 14t baler that is breaking the shear bolt by the plunger hitting the stop every time. I have ordered an owners manual and will refer to that once I have it, but in the meantime, when folks talk about asjusting the timing on the baler, what parts are adjusted to do that?
Is the arm that rotates that moves the needles the piece that is adjusted?
I didn't want to just start taking pieces off and moving them around blindly.
I have read the other posts here with regards to this baler and have tripped action to start the knot cycle while rotating the flywheel by hand and can see where the conflict is, but I need to know which piece it is ok to adjust it with.
Thanks for any help you can provide!
Wayne
07-13-2004 19:44:43
 Re: 14t Baler questions... in reply to Tim, 07-11-2004 20:18:27
Have you checked needle brake? If needles don't stay in home position plunger stop will be engaged. Adjust by removing lower pin in linkage and pull towards rear of bale case proper tension should be 17 to 22 lbs. of pull on scale.If brake has worn to much part that doesn't touch brake disk can be ground off some .
Tim
07-13-2004 21:31:37
 Re: Re: 14t Baler questions... in reply to Wayne, 07-13-2004 19:44:43
The problem is the needles aren't getting to home position...
The problem seems to be worn chains, I replaced the one up front and it helped a good bit, tomorrow I will replace the feeder chain.
Replacing the front ( main ) drive chain brought the knotter wheel to the very edge of reaching home position, so I think replacing the feeder chain and maybe the knotter chain will take care of it.
The drive chain and feeder chain look like they might be original equipment...lol.
Bob
07-11-2004 21:55:56
Before attempting to time your baler, start out with roller chains that drive the fingers in the feeder, and the knotters, in NEW or in VERY GOOD CONDITION!
Timing is accomplished installing the roller chain that drives the fingers in the feeder when the plunger is at a specified point, and the fingers are "X" number of inches from the RH side of the plunger.
The knotters are timed by installing the roller chain that drives them when the rear face of the plunger is "X" number of inches from the needles, as they have started to rise, and are flush with the bottom of the bale chamber.
I wish I could remember the exact dimensions, but by the time I get to the farm tomorrow (where my operator's manual is) I'm sure someone else will have posted the exact measurements.
If the fingers in the feeder are out of time, either the plunger will snap them off, or the baler will not feed properly (and will fail to make the bales even from side to side).
If the chain driving the knotters is out of time, the result will be missed ties, broken shearpins (as you describe), or broken needles.
As I said before BE SURE to use new chains, or very good used chains with very little wear. Replacing worn chains is not cheap, but cheaper than feeder fingers, needles, or knotter parts, and worn chains will very likely "ride" the tips of the sprockets and "jump time" again.
doug cahill
06-11-2005 18:18:45
 Re: Re: 14t Baler questions... in reply to Bob, 07-11-2004 21:55:56
I am needing to know how to thread the twine on a 14t baler up to the knotters
Tim
07-12-2004 11:16:25
Bob, any chance you got those dimensions you mentioned?
The chains appear to be in good shape on this baler, I tried adjusting the knotter timing today but it keeps ending up to early or to late it seems.
ET
07-12-2004 12:14:05
 Re: Re: Re: 14t Baler questions... in reply to Tim, 07-12-2004 11:16:25
Someone probably took a link out of a stretched chain to tighten it up. Count the links and check it against what the parts book says. Those chains need to have the correct number of links in them.
Tim
07-12-2004 12:54:43
 Re: Re: Re: Re: 14t Baler questions... in reply to ET, 07-12-2004 12:14:05
Does anyone have a parts book or manual for this baler they would don't need any longer?
Thanks!
Tim
Brian
07-12-2004 18:27:06
 Re: Re: Re: Re: Re: 14t Baler questions... in reply to Tim, 07-12-2004 12:54:43
Tim I have a manual for a 14T. Ifyou did not find one buy now let me know I can try to copy the pages you need and send them to you. Brian
Tim
07-12-2004 18:41:59
 Re: Re: Re: Re: Re: Re: 14t Baler questions... in reply to Brian , 07-12-2004 18:27:06
Brian that would be great if you could do that, or even scan them and email them to me...
My email is [email protected]
Bob
07-12-2004 20:36:05
 Re: Re: Re: Re: Re: Re: Re: 14t Baler questions... in reply to Tim, 07-12-2004 18:41:59
Tim,
Were you able to get information you needed sen to you? I can't seem to track down my 14T manual here at the farm.
Perhaps it has been lent out once too often. I will quiz the BIL in the morning, as to it's whereabouts!
Tim
07-12-2004 21:50:48
 Re: Re: Re: Re: Re: Re: Re: Re: 14t Baler question in reply to Bob, 07-12-2004 20:36:05
No, I haven't got the info yet...I am trying to obtain a manual as well.
Bob
07-12-2004 23:33:50
 Re: Re: Re: Re: Re: Re: Re: Re: Re: 14t Baler ques in reply to Tim, 07-12-2004 21:50:48
As you may be aware, there's one on ebay right know, #3826559145.
Also, you can get them direct from Deere, $30.00, I think, by calling 1-800-522-7448.
Tim
07-13-2004 07:53:37
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 14t Baler in reply to Bob, 07-12-2004 23:33:50
Bob, I think your advice on the chains is right on. I think the feeder chain is worn, the idler adjustment to take up slack is maxxed out. The chain driving the knotter looks new.
The problem I'm having is that the knotter doesn't make it all the way around to its "reset" position before the plunger comes back down and hits the stop. I am thinking that is possibly caused by the worn feeder chain, maybe a worn chain up front as well.
I saw that manual on ebay and thanks for the 800 number for the manual as well.
Tim
Tim
07-13-2004 22:56:50
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: 14t Ba in reply to Tim, 07-13-2004 07:53:37
Besides the wear, the chain has probably jumped cogs, or was installed wrong by someone REALLY putting things out of time!
ET
07-12-2004 09:45:02
Don't forget the chain right up front by the slip clutch. That one drives everything and times the plunger. It usually wears the most.
