3020 Tires are too far out
Conrad
07-11-2004 19:28:22
I Just bought a nice 3020, but the rear wheels are positioned all the way out. I would like to pull them in. This will give a better fit on my trailer. It is a little unnerving only having 3 inches of clearance per each side. Can any one tell me how to do this? Is there any shop manual that would help me with this job
Thanks Conrad
Russ
07-12-2004 18:21:55
 Re: 3020 Tires are too far out in reply to Conrad , 07-11-2004 19:28:22
Hub mover; If your going to trailer several times a year adjust your traction rear tires per the repair manual instructions.
If you need to get it to a site just once or twice hire a platform truck and feel great about all the time you will save. A wide stance is a safer tractor. Good luck.
Elden Denning
07-12-2004 08:33:58
Get an operator's manual for your tractor, money cannot be better spent, it will have all the procedures for spacing the wheels and other precious information you will need from time to time. Seems to me 3 inches on each side is plenty of deck beyond the wheels, you'ld have to flip the trailer to slide the tractor off if you legally and properly secure it on your trailer.
leland
07-11-2004 21:24:19
After you get done sweating your butt off getting wheels in MAKE sure you recheck bolts on hub. They will need retightend again found out the hard way ruined a hub, what a pain to replace.
Heat Houser
07-11-2004 20:51:26
two choices, jump the rims "in" in relation to the cast center hub or slid the whole mess on the axle. To slide on the axle, loosen the 3 outside hub capscrews, tighten in on the 2 smaller forcing screws and this may push that half of the taper wedge out. On my 4010 I loosen the 3 inner capscrews in addition to the outers and then drive forward and then pop the brakes. This has worked every time to get the wedges to loosen. Jack up the side you want to move, rotate the wheel until the rack and pinion are up and using a wrench, move the mess in. If the rim is not reasonably centered on the cast center hub, it may be a bit more of a tussle to get them to slide in.
Huckleberry
07-11-2004 20:46:19
you will need an operator's manual. its a fairly simple procedure. you need an operator's manual anyway. see other pages on this site to order.
