1955 John Deere 60 L P (3 questions)
Irv Plitzuweit
07-11-2004 19:20:15
I am in the process of restoring a 1955 JD 60 LP and don't have operators manual yet.
Que # 1 involves starting it. I know you start on vapor, but there is no choke on this one, should there be? full throttle or less?
Que # 2 Should the lights be green or black?
Que # 3 Bought a new muffler with the slight indentation (dent) in it. Does this face forward or back?
Kerry
07-12-2004 20:15:45
 Re: 1955 John Deere 60 L P (3 questions) in reply to Irv Plitzuweit, 07-11-2004 19:20:15
Irv,
Experiment a little, my 1955 50LP likes to be at idle or a little above when I start it. Also, I don't have a choke but I have a little electric pushbutton that gives it a little shot of propane. I give it a couple of quick shots (maybe 2 1-second shots) if it's cold, otherwise just set it at idle and start it.
Yours may (probably will!) be different, just see what your tractor likes.
shotgun
07-12-2004 20:12:26
I got a 54 70 lp that dont have a choke
CLW
07-11-2004 21:05:38
moline, is correct, lights black and the muffler is most likely for styled A. Is it 22 inches tall? The muffler for the 60 is a little longer and no dent but most people won't notice. As far as the choke, I don't know why it don't have one but you more than likely would never need it. I set my throttle (630LP) about one third open and it starts good cold or hot. You will find the best setting as all are a little different.
CLW
Irv Plitzuweit
07-12-2004 18:59:13
 Re: Re: 1955 John Deere 60 L P (3 questions) in reply to CLW, 07-11-2004 21:05:38
Thanks for the info.
Irv
moline
07-11-2004 20:27:48
Irv,I am restoring a 1954 model right now and mine has a choke as well as a primer button on it.My lights were black.The muffler sounds like the one on my A.The A tractors had a dent in one side to clear the steering shaft.This (dent) would face the left side of the tractor.The 60 has a higher mounting for the muffler and does not require this dent.Hope this helps,moline.
