Steve, I will try n answer your questions in the order they were posted. 1) BATTERY: Of course, the battery had to be changed from 6 to 12 volts unless one uses 2 six volters in series. 2) GENERATOR: It was likely changed from a 6 to a 12 volt and its label may show what it is. HOWEVER, its possible to still use the old 6 volt but just change the Voltage Regulator from a 6 to a 12 and they will work, Ive done it. Basically a Gen dont know what voltage its supposed to be, it increases if its turned faster or you pass more field current through its field windings, which is part of the Voltage Regulators function. If what you have works, no problem. If you ever need a total new Gen, I would buy a 12 volt unit (also a 12 volt VR of course) 3) STARTER: It may have been changed, but myself and many others just use the old 6 volt starter. As long as its not let to crank long periods and overheat its windings, they generally work okay at 12 volts, and they spin fairly rapidly. It may be a tad tougher on starter drives due to the high starting torque. If you ever had to buy a total new one, I would get a 12 volt, but if yours only needs minor repairs like brushes etc, I would just repair it. 4) COIL. It may have been changed to a 12 volt internally ballasted unit or they may have simply (whats often done and I do) added an external voltage dropping ballast resistor to drop 6 volts leaving 6 across the coil as it was designed for. Do you have one of those external ceramic bathtub type ballast resistors in series in the circuit from the ignition switch down to the coil or not????? ??? If you apply 12 to a 6 volt coil, it will run real hot and may degrade the insulation from overheating (may get so hot you can hardly lay a hand on it, if so it may be a 6 volter) plus the points will burn up quicker. 5) VOLTAGE REGULATOR: YES, it definitely has to be changed to a 12 volt unit, regardless if the Gen was changed or not or it wont charge properly. It should also be rated for Positive or Negative ground to match your tractor. 6) POINTS AND CONDENSOR: They are basically the same regardless if on a 6 or 12 volt tractor. Points are simply mechanical current switching devices used to turn coil current ON (points closed) or OFF (points open) and dont care if it�s a 6 or 12 volt system. Of course, they must have a DC Voltage Withstand Rating so they don�t arc and their insulation can withstand potential difference of a certain voltage, but its much higher than 6 or 12 volts anyway. Sooooo ooooo, the main things you need to be concerned with are the Voltage Regulator and Coil or the Coil and Ballast Resistor total must be for 12 volts. A true 12 volt rated coil needs no external ballast as it already has an internal one, but if you have a 6 volt coil, you need the added series external ballast (around 1.25 to 1.85 ohms or so) in the ignition circuit from the Ignition switches IGN output terminal and the coils input to limit current. A 6 volt coil will have around 1.2 to 1.8 ohms or so DC resistance in its primary winding between the lil + and � terminals, while an internal ballasted 12 volt coil has 2.5 to over 3 or so PLUS it may be labeled 6 or 12 volts. I hope this answers your questions, Hopefully others may post additional tips or opinions. Post back or e mail [email protected] any questions. Good Luck n God Bless ya Steve John T Nordhoff in Indiana
