2010 PTO update missing gear?
rex
01-30-2004 14:34:18
This is an update from my earlier post I asked the boy who I bought it from about the PTO he told me that his father had removed a gear from it as he only used the tractor for planting, anyone please help me on what to start to look for and where to start disassembly to look for the problem. Thanks Rex
Joe Stewarts
01-30-2004 20:50:26
 Re: 2010 PTO update missing gear? in reply to rex, 01-30-2004 14:34:18
I've disassembled mine several times to work out all the bugs in it. The "gear" the po referred to could be in the pto clutch compartment (normally dry) or it could be one of the cogs in the pto case (normally wet i.e. filled with lubricating oil). I guess the first question I would ask you is what does the pto do when you engage the lever? Is there any response whatsoever? Do you feel any resistance when you move the lever? Do you hear any clicks or grinds? Next question: Is there oil in the pto case? Next question: Do you have a manual? If not, get one and turn to the section on removing the rockshaft cover. Use an engine hoist or overhead crane to remove rockshaft cover and visualize the pto linkage and make sure everything is hooked up right. If all that is fine, remove pto case and look inside to see if any of the cogs in there are gone. Sounds difficult and complicated but all the above can be done in one day. I'd bet that the missing link is somewhere in the pto clutch compartment. One more thing: many of the pto parts are obsolete and no longer available from Deere. I ended up getting a good used gear and shaft from Worthington Ag. Joe Stewart
rex
01-31-2004 03:31:24
 Re: Re: 2010 PTO update missing gear? in reply to Joe Stewarts, 01-30-2004 20:50:26
Thank you for your response Rex
rex
01-31-2004 03:35:43
 Re: Re: Re: 2010 PTO update missing gear? in reply to rex, 01-31-2004 03:31:24
I guess it would have helped if I had answered, first off I feel no resistance at all in the pto lever it just feels like something is not hooked up I can't imagine why anyone would go to all the trouble to remove a gear and not replace it. Thanks rex
Joe Stewart
01-31-2004 14:59:38
 Re: Re: Re: Re: 2010 PTO update missing gear? in reply to rex, 01-31-2004 03:35:43
In that case, it sounds like the linkage was just disconnected. A simple fix, but you still need to take off the rockshaft housing. Its good to have the manual because if you fail to disconnect the oil supply tube to the rock shaft, you'll snap it off, and then you'll be in way bigger trouble. Get the manual and follow the procedure. Inspect the linkage while moving the pto shift lever once the housing is off and see what the problem is. I'll send you a copy of the pertinent pages in the manual if you can't get one. Good luck. Joe Stewart
