1936 JD A
Denny
07-11-2004 16:45:13
I am in search of 9 bolt hubas for my '36 JD A. I've been told an Oliver 77 or 70 hubs will work? If anyone knows which one will work if either will. Any help locating hubs to put tin rims on would be appreciated. Thanks, Denny
CMB
07-13-2004 10:52:14
 Re: 1936 JD A in reply to Denny, 07-11-2004 16:45:13
Just found an ad in the July Green Mag that lists what I think you are looking for. He might still have them. The # is 989-561-5124
CMB
07-12-2004 10:12:30
The hubs from a '44 should be 15 spline & the '36 are 10 spline. I just don't know if there's anything out there that would fit without a lot of machine work. Maybe someone with more knowlege/experience than I should step in here.
JDBert
07-12-2004 08:01:36
The oliver ones wont work, the A has a splined hub not keyed. I have a set off a 44' A but not sure if the splines and size of the axe are the same.
