530 hydrolic leak and front rockshaft?
WjW
07-11-2004 15:14:03
I have two questions,
1) There is an add for a front rockshaft that fits 520/530 tractors in the green magazine. I have heard and seen front rockshafts for new gen and newer tractors but for 30 series? are any of you familiar with this? Is it an independent, hydrolicly operated, or would it use a reach rod from the back rockshaft?. I see in the latest green magazine featured artical there is a beet picking machine on a 60 that has a front mounted piece of equipment on it that I could see being called a front rock shaft. Is this front rockshaft gizmo similar or the same? would this front rockshaft be a Deere thing or a after market?
2) My nieghbor has a 530 and says the trans fluid goes up every time he fills the hydrolic res. I do not know if he is loosing the level in the hydrolic res. as a result of operaton or if it goes away when sitting. I have a few ideas but thought I would ask for some of you fellows wisdom, is there a typical failure that he should go after? sory I don't have better specifics but my wife took the call... she doesn't get details and I haven't had time to go see him?
Thank you folks in advance for your help!!
WjW
