Diesel tach
Rick
07-11-2004 14:05:54
Can a diesel engine RPM reading be taken from an alterantor lead? If so which lead field, arm., bat.?
Bob
07-11-2004 18:03:49
 Re: Diesel tach in reply to Rick, 07-11-2004 14:05:54
Alternators designed for this have an extra terminal, "STATOR" that is not always available on other alternators. This is a lead, internally connected to one of the 3 stator leads, and connected to a terminal that extends outside the alternator for easy connection.
Delco 10SI and 12SI alternators have a hole in the back for the terminal stud to pass through. On some Delco alternators, there is an extra "notch" in the case, next to the 2-wire internal regulator connection, for a third flat quick-connect terminal for the stator connection.
If your alternator does not have the "STATOR" terminal, a local alternator shop should be able to add the terminal, or swap you for an alternator that does have it.
Rick
07-11-2004 18:28:56
 Re: Re: Diesel tach in reply to Bob, 07-11-2004 18:03:49
Bob, Thanks for the information!
