JD #8 Mower question
Hayfarmer
07-11-2004 09:11:12
Does anyone have a #8 or 8W with the cable lift, correct one that is that hooks on the right side on the arm that raises the mower? Mine was adapted from a hydraulic cylinder model. I need the somewhat triangular shaped bracket that goes on the lift arm. Igf someone could give me dimensions, height etc I could probably make one.
ET
07-12-2004 07:04:07
 Re: JD #8 Mower question in reply to Hayfarmer, 07-11-2004 09:11:12
Are you trying to go back to the cylinder from the cable lift? Is the triangle part you need the rear cylinder bracket that bolts to the frame back by the casterwheel? I may have what you need. Does your mower have the float spring on it?
