730 D
R MOORE
07-11-2004 08:08:17
I am in the process of putting the thrust washers back in my 730 diesel electric start.I got the exhaust manifold off.And was pulling the upper water pipe off so i could get the governor up when i lost a considerable amount of water right down into the head.How do i get the water out of there?
DON
07-11-2004 08:13:14
 Re: 730 D in reply to R MOORE, 07-11-2004 08:08:17
REMOVE THE INJECTORS AND CRANK IT OVER.
F-I-T
07-11-2004 08:34:27
 Re: Re: 730 D in reply to DON, 07-11-2004 08:13:14
Why remove the injectors? Couldn't you just open the decompression lever?
What am I missing?
cole in mo.
07-11-2004 09:02:33
 Re: Re: Re: 730 D in reply to F-I-T, 07-11-2004 08:34:27
I'm wondering if there was a large amount as he stated, the water wouldn't be pushed out and would just run back in with the next opening. I don't know, just a thought.
F-I-T
07-11-2004 09:41:52
 Re: Re: Re: Re: 730 D in reply to cole in mo., 07-11-2004 09:02:33
Well, perhaps so. On my 70D, I think it would be easier to remove the 4 bolts and take off the exhaust manifold, then snarf out the water with a shop vac. I just hate to disturb the injectors if I don't have to.
Frank
R MOORE
07-11-2004 10:19:23
 Re: Re: Re: Re: Re: 730 D in reply to F-I-T, 07-11-2004 09:41:52
In the process of putting the gears back on i had to put the flywheel back on to turn everything to get the gears back in time.All the water dissapeared.I think it dropped down into the oil pan going to pull the plug and see here in a few minutes.
