2240 lift arms
ps claybaugh
07-10-2004 09:15:16
lift arms are stuck in the up position and will not come down. i only have a draw bar on the hitch pulling a side del rake.
ps claybaugh
07-11-2004 09:14:01
 Re: 2240 lift arms in reply to ps claybaugh, 07-10-2004 09:15:16
rate of drop is ok, ihave applied down preasure
on the arms overnite and they have come down but still don't work. all other hydraulics work,ie loader.
david val
07-12-2004 01:10:15
 Re: Re: 2240 lift arms in reply to ps claybaugh, 07-11-2004 09:14:01
the rockshaft assmbly should be removed and serviced. pay particular attention to the load control mechanism.
david
david val
07-11-2004 01:46:40
check that the rate of drop valve under the seat is not closed tight. initial adjustment is one turn out.
david
