36 AR Crank and cam
tony
07-10-2004 08:35:16
I am in the process of putting back together my 36 AR and on the crank I have not found any marks and on the cam there are two different marks. My questions is, without any marks on the crank by turing it to the crank in the forward position can it be put together with the cam just closed on the intake (inside lifters)? It seems to work good and in time, on the governor and cam markings, how does the governor line up to the cam? Do the marks do line up to those? Thanks for the inputs.
Tony
ET
07-11-2004 04:00:40
 Re: 36 AR Crank and cam in reply to tony, 07-10-2004 08:35:16
The marks for timing the crankshaft and cam should be the ones on the inside of the camshaft drive gear away from the main bearing. The mark is close to the crank throw and can be hard to see. The other marks on the cam time the governor gear.
tony
07-11-2004 19:35:17
 Re: Re: 36 AR Crank and cam in reply to ET, 07-11-2004 04:00:40
I want to Thank You for the info, I have never had to take a tractor down this far so it is a learning experience for myself. Found the little marks that you mentioned and got them marked in paint for ease later. I was only off by three teeth, so it will be fixed tomorrow.
Will post pictures of this later.
Mike M
07-12-2004 13:06:33
 Re: Re: Re: 36 AR Crank and cam in reply to tony, 07-11-2004 19:35:17
As a learning experience for next time please note , verify the marks and or make your own BEFORE you tear it apart. This is good advice for most things mechanical.
