60 draining battery PART 2
Fred from MO
07-10-2004 03:51:38
I posted a message about a month ago and got some great responces from Frank and Clooney-Thanks. ( I have not divulged into all the suggestions with trouble shooting this one, however I noticed one other thing yesteday)--- My original problem is the 60 is draining the battery when left hooked up in the tractor-even without running. I charged the battery yesterday and took the tractor out of the shed to power wash the years of grease off of it before I paint. I noticed that while the tractor is not running and the battery is hooked up, the generator gets warm/hot physically (I noticed this when the steam was rising off the outside of the generator case when it got wet). I believe this is the drain on the battery. What would cause the generator to become hot? The battery is hooked up positive to ground-are all 60's this way? Would this mean the generator is bad? My previous post I stated that the amp meter was not working. Now the amp meter shows -12 when the battery is hooked up. Any more suggestions would be much appreciated. I think some advice in my past post was that it was a bad Voltage Regulator. Now that I know the generator is getting hot, would a bad VR cause this?
Thanks
Fred
John T
07-10-2004 07:33:18
 Re: 60 draining battery PART 2 in reply to Fred from MO, 07-10-2004 03:51:38
Good Morning Fred, Sorry if I didnt contribute to the previous post you mentioned, but maybe I can help a little bit until Frank or Clooney arrives.
1) YES all 2 cylinder Deeres were connected as POSITIVE GROUND.
2) YES, a bad Voltage Regulator (if cutout relay sticks closed) could cause the problem you described of a hot generator and ammeter showing discharge when tractors off. (The Gen is tryign to turn as a motor, but the belt wont permit that so it gets hot)
NO its doesnt usually mean the Generator is bad, its more likely the Voltage Regulators cutout relay is bad/stuck closed. Does it show charge when running????? ? If so, the Gen is okay and the reason it discharges and heats up the Gen with the tractor off, is cuz of the bad VR.
3) HOW TO TELL IF THE VR'S CUTOUT RELAY IS STUCK CLOSED. With the tractor turned off unhook the wire connected to the ARM (or Gen) terminal on the Voltage Regulator (or you could unhook it a the Armatur post on the Generator itself) and see if the ammeter then goes from discharge to zero and the Gen cools off ???? If so, whats happening is the cutout relay contacts inside the Voltage Regulator are stuck/burned/welded/corroded shut and the Generator is drawign curent acting as a DC motor and its running the battery down plus heatign up its windings. ALSO, with the tractor off if you removed the belt so the Generator could turn and it spun like a motor, thats another sign the Votage Regulators internal cutout relay is stuck closed allowing battery current to flow through it.
4) THEORY OF OPERATION: For the Generator to get to and charge the battery when running, it has to have a connection to it. But then when the tractors not running, it has to be disconnected or else the Generator will draw current out of the battery and dischage it and try to turn as a motor and heat up if it cant turn caise of the attached belt. To prevent that (battery discharge and heat up Gen windings) theres a cutout relay inside the VR which is supposed to close when the Gens output voltage is higher than the batterys, but then open back up otherwise like if the tractors off so the battery dont run down and the Gen heat up and act as a motor.
It may be possible to unstick the cutout relay contacts ann file them smooth and remove the carbon and pitting and welding so they work again, but once the silver coating is removed from them they usually go bad again and need replaced.
SUMMARY: If when you shut the tractor off the ammeters swings to discharge and the Gen heats up, its cuz the Voltage Regulators cutout relay is stuck closed and not opening as its supposed to do. If removing the Gens Armature post wire makes the ammeter return from discharge back to zero, the relay is stuck closed.
GET A NEW VOLTAGE REGULATOR if the tests above shows the cutout relay is stuck closed. You may first try n fix it, but it could stick again if its badly burned or pitted or the VR has other problems.
I hope this helps until Frank or Clooney arrives with other ideas or opinions. Post back or e mail me at [email protected] wiht your findings and any other questions. If you need detaield Gen and VR tTroubleshooting Tips, post back or e mail n let me know also. No use postign all tnat now unless and until you need it. If the ammeter shows charge when running, the Gen is okay as the cutout relay is supposed to be closed then anyway and it beign stuck closed wont hurt things then
Good Luck n God Bless ya Fred
John T in Indiana
Fred from MO
07-12-2004 21:22:17
 Re: Re: 60 draining battery PART 2 in reply to John T, 07-10-2004 07:33:18
That was it guys!! I took apart the VR and found that the left hand side (if you are facing the generator) contact was welded closed. I pryed it apart with a screwdriver, but intend to replace it. JD dealer wants 35 bucks for one.
Thanks for the help.
F-I-T
07-10-2004 07:07:09
Fred:
Yes, a bad VR can/will cause this. It sounds as though you might have a burned or stuck contact in the VR that is not letting go when the generator is at rest. The VR acts as a voltage sensing relay, and it needs to let go when proper voltage has been achieved. This is probably the cause of your 12 amp drain. If you remove the fan belt, depending on which contact is sticking, the generator might even turn like a motor. That's likely why it is getting hot.
Have you used the light bulb or buzzer trick? That would let you find a "ghost" load. To do that, hook any sizable wattage lamp bulb in series with either battery cable. If it glows, current is flowing which is not good. Then you disconnect wires, one terminal at a time until the lamp goes out and you have found the area of your problem. There's not many wires on a '60' to trace.
BTW, all John Deere Products through the two cylinder era were positive ground, but the advice works either way.
Frank
