70Gas engine drive PTO and brakes
Jack
07-09-2004 22:02:50
I have always only had the one brake lock lever on the LHS of the tractor. I looked at it today to see if I can put a RHS lock on it but I see that the engine driven pto lever, when its at rest in the lowered position is in the way of where a brake lock would have to travel.
Am I missing something or is some thing not right om my tractor? The shaft for the brake lock is there but putting it on would be useless... unless the pto is on with lever pulled up.
Thanks
Mike M
07-10-2004 08:30:55
 Re: 70Gas engine drive PTO and brakes in reply to Jack, 07-09-2004 22:02:50
You probabaly will need to rebuild the pto linkage to get out the extra slop first.Put in oversized pins, building up the worn holes with a welder and redrilling them,etc. If you can't get out slop enough on the outside linkage you may have some extra wear on the bronze tips that go into the pto shifting fork on the inside of the unit.
Jack
07-10-2004 10:55:11
 Re: Re: 70Gas engine drive PTO and brakes in reply to Mike M, 07-10-2004 08:30:55
I never even thought of wear, but it makes sense. If I read you right, the handle should be higher when at rest, than where it is resting on mine now? Mine rest on the brake lever shaft.
If anyone can post a photo of where it should rest, a million thank yous.
