JD 2750
Kent Hamm
07-09-2004 14:46:20
I have a John Deere 2750 about a 84 model & would like to know what is wrong when you have to turn the sterring wheel back & forth to get it to turn over fast enough to start
allen
07-10-2004 04:26:13
 Re: JD 2750 in reply to Kent Hamm, 07-09-2004 14:46:20
what you are doing when you turn your steering wheel back and forth is destroking your hyd pump,what that means you are not driving the pump until tractor gets running, there is a kit that you can get to do this atuomaticly, they will start with out this, so either your starter needs to be rebuilt (starter is turning over slow maybe bad bearing etc) or you have a bad battery, your dealer can help you out
