Early Styled B lower water pipe
Jason Z in MO
07-09-2004 12:24:01
A couple days ago I had a post talking about repairing the coolant pipes on my tractor. Since that post I have ordered the replacements. Mike M. thanks again for your help with that!
The upper pipe is perfect compared to the original. It has 3 bends and matches perfectly. However, the lower pipe I received was about 4" shorter than the old one which is 20 1/2". Written on the new pipe was "use hose to make up diff." The other difference is the old had a few degrees of bend at one end. If I remember it was toward the radiator; (tractor is torn apart now so I can't confirm). New pipe is straight (no bends) steel pipe 2 1/4"ID 2 3/8"OD.
I know this is probably pretty minor to most people but I would like to keep this as original as possible. Besides, a few more inches of pipe is probably cheaper than a few inches of hose.
Stan, how is yours set up?
Stan - Florida
07-12-2004 18:55:16
 Re: Early Styled B lower water pipe in reply to Jason Z in MO, 07-09-2004 12:24:01
Jason,
If I'm the Stan you're asking, I don't remember, as I did my '41 B over ten years ago. I'm also not home for a while and can't go out and look at it.
I did buy a lower water pipe from my local Deere lawn and garden tractor dealer and it had a bend which I think was at the lower end, but I wouldn't bet on it. Just can't remember the dimensions but I did use a radiator hose on the front end.
Good luck,
Stan Huff
Melbourne, FL
Mike M
07-10-2004 08:44:09
Jason; I would try what m Johnson suggested about the electrical conduit. I had a friend make me some for and unstyled B. I would just pattern after your old one as it sounds right. Got any friends or relatives that work in maintenance at a large factory,some of these have thier own benders. Or check with a local electrican. I have had the local exhaust shop bend some allready but the bends are not smooth like electrical conduit is.
BMAN
07-09-2004 16:48:51
If you have an early styled B I think you need a 2 1/2 OD pipe. The Unstyled B's are 2 3/8.
m Johnson
07-09-2004 14:07:13
I use electrical conduit of the proper diameter.
An electrician freind of mine makes the bend in his bender and I cut the conduit to length.
It works as good as an original and looks the same.
Take a bevel tool, and calculate the end bend with a straight pipe as a referance.
Be sure to extend the bend past the fan support or it may be difficult to get a hose clamp on it.
Best of luck.
Bguy
07-09-2004 13:36:42
Jason, Sounds like you have a long frame B and a lower water pipe for a short frame B. They are right in that you can just use a longer hose and you are right that this isn't really the way it ought to be. Starting in late 1937 they made the frame (and the water pipes, fan shaft, etc) longer so the B could use the same frame mounted implements as the A. One of the salvage yards should have the longer pipe, just specify that it's for a long frame unstyled B.
Bguy
07-09-2004 19:39:15
 Re: Re: Early Styled B lower water pipe in reply to Bguy, 07-09-2004 13:36:42
Jason, I mis-read your post, I was thinking you asked about the unstyled B's. Still, Any good salvage yard should have the pipe you need.
