4020 syncro range jumps out of 8th
Dan
07-08-2004 18:37:51
My 1969 4020 with the syncro range trans, jumps out of 8th when I am changing gears from 6th to 8th. Could it be the shifter forks that are wore or the shifter cam?
Jason Z in MO
07-09-2004 08:42:56
 Re: 4020 syncro range jumps out of 8th in reply to Dan, 07-08-2004 18:37:51
Dan,
You might want to try adjusting the linkages. A long time ago (I don't remember all the details) but my 4020 sycro was jumping out of 3rd. I followed the linkage adjustment procedure described in the service manual and it shifts much easier in all the ranges.
I might have just gotten lucky...
Jason
ET
07-09-2004 07:19:02
Try not slaming it down into 8th, you may be moving the shifter to far. It seems to be human nature to wined it up in 6th and dump it into 8th. Does it jump out of 3rd, 5th or 7th they are all the same shift? The kit Mike M. reffers to is a heavy duty synconizer kit that adds extra disks to the high range syncronizer and a support guide pin.
Mike M
07-09-2004 09:19:52
 Re: Re: 4020 syncro range jumps out of 8th in reply to ET, 07-09-2004 07:19:02
That sounds like the kit. What problem/problems was this to fix ????
Mike M
07-09-2004 05:14:29
In the 1980's when I worked at a John Deere dealer I seem to recall a 1 owner low houred 4020 came into the shop and the tranny got split and some kind of an updated shifter fork with I think a stabilizer pin into it.I do not however know what gear/gears this affects so there is or were updates available. I don't know where you can find any copies of these old bulletins maybe a Jd dealer can still find them. You may try www.4020.com
Albert
07-08-2004 20:06:39
Ours had similiar troubles with slipping out of park and the forks were the problem good luck
