G wheel adjustment
bob
07-08-2004 08:57:09
having a tough time moving wheels on 48 g.have tried all the various tricks to no availe.i have a 12 ton jack pulling and a 10 ton pushing,have heated and soaked it with gibbs.so far they have not budged.i guess i need a bigger hammer.
are there any fresh ideas out there without cutting the hubs off?thanks for any help. bob
CMB
07-09-2004 07:21:29
 Re: G wheel adjustment in reply to bob, 07-08-2004 08:57:09
A number of wears ago I worked part time in a local welding/machine shop. A customer was building a "G" pulling tractor. He brought th "Power-Trol" & the axles & hubs. I built a 12lb "flatback" out of sheet metal & strap iron to replace the 300+lb hydraulics. We put the axles & hubs in a 50 ton press. One let go at just under the maximum capacity of the press, the other wae raised to the limit without moving. After heating with a "rosebud" torch, it finally let go. Both made a sound like a rifle shot when they finally moved. Hope you have better luck than this with yours.
Jeremy L.
07-08-2004 10:52:42
Boy I've been there! I had to move my G's wheels in this winter, so it would fit on my trailer. I did the same thing, had a peice of 1/2 inch angle iron, chains with bolts through the wheel and pulled hard as I dared....heated and beat. Nothing. Walked away from it on the second day of trying. Made a new puller. This time had a peice of 1" flat steel on the end of the axle with 3 peices of 7/8ths threaded rod (or bolts, not sure anymore) Stuck the threaded rod through the hub and put on washers and nut. Then tightened evenly at the plate with the air gun. Little bit of heat I think. (We decided that the first time we heated too much and so were actually heating the axle, which wasnt helping anything). Eventually this pulled the wheel off. I wire brushed the axles and coated everything in never-seize, and now 1 guy can slide the wheel anywhere on the axle. Guess thats how its supposed to be! I couldnt believe that those 3 bolts could pull more than a 12 ton jack, but it did. If you're feeling lucky I read in the archieves of this board of some people heating the hub and axle up with a torch, then pouring on a 5 gal. bucket of water. I didnt have the nerve to do that.
g pop
07-08-2004 14:23:55
 Re: Re: G wheel adjustment in reply to Jeremy L., 07-08-2004 10:52:42
we have had good luck soaking the axel and hubs for a few days ,then using an old farmall f20 flywheel puller and two long 3/4 ready bolts and a little heat on the axel sometimes it takes, a few trys,let it cool down each time.
36 A
07-08-2004 20:07:28
 Re: Re: Re: G wheel adjustment in reply to g pop, 07-08-2004 14:23:55
I to was just going through what you are .My hubs stuck a 1/2 inch out past the axleand i kept heating and nothing.A frend came over and took a 1" 4by4 steel plate and welded a handle on it and with a few strock of a bbbig hammer they slid in flush.then with a big puller and a air chisle with a blunt end started back off.Now dont get me wrong it was still a lot of work but they came off.And my frend said i thout you said they were stuck?! 36 A
