COMPRESSION RATIO AND PISTON RINGS
DAVE SIEKKINEN
07-08-2004 06:08:13
I'M WORKING ON A 1944 "A" AND WAS WONDERING WHEN I COPMRESSION TEST IT WHAT THE PSI SHOULD BE. THE TRACTOR RAN WELL BUT THE HEAD CRACKED DUE TO FREEZING. I WAS WONDERING IF I SHOULD JUST RE-RING THE PISTONS WHILE IT'S TORN DOWN THIS FAR. BEFORE I TORE IT APART I TESTED THE COMPRESSION AND IT SEEMED TO ONLY GET INTO THE 30'S FOR PSI. THE CYLINDERS ARE IN NICE SHAPE. WHEN RE-RINGING A TWO-CYLINDER, DO YOU USUALLY JUST RUN A HONE THROUGH THE CYLINDERS? HOW MUCH IS INVOLVED IN REMOVING THE BLOCK AND PUTTING IT BACK ON? THANKS, DAVE
G-MAN
07-08-2004 07:48:02
 Re: COMPRESSION RATIO AND PISTON RINGS in reply to DAVE SIEKKINEN, 07-08-2004 06:08:13
In addition to Ron's excellent info, once you have it back together and running, take it out and WORK it. It takes heat and pressure to seat piston rings, and putting around the yard just won't get it done, particularly with today's excellent oils. I would recommend running JD break-in oil in it for several hours of hard work to get it seated in correctly. I'm currently finishing a full rebuild of a "70" and will put in break-in oil and run it on the dyno for break-in and adjustment. This will be the first time I've ran it in a two-cylinder, but it works very well in the modern engines and is factory-fill from Deere in order to assure good ring seating.
Ron
07-08-2004 07:02:56
You can pretty much tell by how much gap there is at the ends of the top ring.. With the head off, look around the edge of the piston and see the gap..if it is 1/4" or more, yes the rings certainly meed replacing... You will need a Ridge-reamer big enough to use on a 5 1/2" bore..you may be able to rent one.. After you ream the top ridge out, you can remove the pistons and rods.. You will have to have a good hone with pretty coarse stones to hone the cylinders.. I use a combination of 10 wt oil and kerosene as a lubricant and add it often..
You need to keep the hone moving in and out of the cylinder--( Back and Forth ) while honeing. It took me about 1 hour of honeing on each cylinder to get the old ring marks out.. You at least have to remove the "Glaze" from the cylinder, or the rings won't ever seat... You will see ring wear marks at the top, and down in the bore where the rings stop at the bottom of the stroke...you need to hone both well..!!! The ridge reamer will leave a sharp edge at the top of the cylinder..use a small round file, or emery paper to remove it, or you will loose some Blood...!! Have the valves ground while it is torn down, and you should be good for another 30 years...!!
