Axel seal retainers-again
Dale
07-08-2004 05:32:22
Has anyone devised a solution to removing rear axel seal retainers on a JD 70 so they can be reused or alternatively, has anyone started to manufacture replacements? I'm not eager to start the seal replacement without knowing how I'll finish. Thanks
1951G
07-08-2004 08:49:19
 Re: Axel seal retainers-again in reply to Dale, 07-08-2004 05:32:22
Dale,
You can order new inner oil seals from awbearings.com. Just give them the number on the back of your seals and they'll ship them to you. I ordered some for my 35A and am quite pleased.
1951G
07-08-2004 08:50:43
 Re: Re: Axel seal retainers-again in reply to 1951G, 07-08-2004 08:49:19
Sorry, I misread the posting. I was only talking about the inner oil seals versus the outer felt seal retainers.
Mike M
07-08-2004 05:58:09
When you remove the axles to get to the inner oil seal which is the real culprit those felt retainers just pop right out and can be reused unless they were allready damaged from a wheel run in too close or previous attemps to remove.
